Thread: Coilover shocks
Old 09-07-2003, 10:31 AM
ACC427US ACC427US is offline
I bought a used kit that was never assenbled. I've taken 2.5 years working on it, primarilly through a "custom rod" shop. I'm barely drivable at this point. My Coil overs are about 13" bolt to bolt. I got them from Shell Valley. SV doesn't give you any detail on the coil weights. However, I can tell you I'm way, way too low to the ground at the oil pan, flywheel, and differential. I'm like 2" off the ground at the oil pan. That's a big reason why I'm still looking at the suspension.
Wheels are Trico-like. Tires are Eagle GTIIs. Front are 235/60R15 and the rear is 295/50R15
I'm running a 427Side Olier with a wet sump with a Tremec TKO 5-speed.
