Fill with the correct amount. You can use a piece of clean, strong baling or other wire to initially check the level.. if you are SURE about the actual amount needed. Mark the correct fill line with a small file notch, and make a hard loop or angle at the top, for a "stop".
Check ALL fluid levels.. my manufacturer delivered my transmission (new Richmond 6 speed!) filled only to the DRAIN plug...
good thing I had it checked right away by a good tranny shop. Check your rear pumpkin also.
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
