ACC427US,
That's low!!! Is there a chance that you have a set of Mustang II 2" dropped spindles installed? I'm running the same front tires, 235/60/15, and the distance from the ground to the bottom of the spindle flat where it mounts to the tie-rod measures around 11 1/4". If you have dropped spindles then this would be closer to 9 1/4".
For your rear height, also check your coil-overs, since an adjustment on the spring compression will make a difference in the ride height.
Drop a post back with what you find.
