Old 09-09-2003, 11:20 AM
dexter dexter is offline
Cobra Make, Engine: SPF #1284 - 392 stroker
Send a message via AIM to dexter
I also have the AC jack and it works well. The model you are probably interested in is the DK13HLQ. It is a low profile, high lift jack which will fit under your Cobra with no problem. Its only drawback is that its rated at 2600 lb rather than 4000.
Yep, actually, the 13 is the one I have, not the 20. I can even slide it under the jacking points on my Corvette without driving up on wooden blocks.
