Old 09-09-2003, 05:36 PM
Softec Softec is offline
Clois,
SCOBRAC is right about the fuel pump cut-off. I used a pressure switch tee'd to the oil pressure sending unit to control the relay for the fuel pump. The pressure switch will stop the fuel pump at 3 psi. The relay and fuse unit are installed in the trunk next to the battery.
