zipzip,
Why the Demon? The Holley is a good carb also, but the Demon is just better thru innovation and new technology. My installation also had alot to due with me deciding to go with the Demon.
#1 Four post idle adjustments. Allowed me to fine tune the idle circuits on an engine with a large amount of overlap.
#2. Rear idle adjustment screw that can be accessed without removing the carb from the engine. I had a small stumble with the Demon at first. Easy fix, just reduce the front idle screw setting and add it to the rear one to achieve the idle RPMs I wanted.
#3 No chock horn assembly, cleaner looking and less air vortec into carb caused by chock horn. I am using a K&N X Stream air filter with ram air being delivered to the top of the carb Via the hood scope and air cleaner filter lid. I could actually hear the chock lid rattling caused by the air passing thru the filter top.
#4 The carb just over all out performed the Holley. Period!
#5 I have another Demon installed on my SBC and was pleased with how it performed on that engine. It helped sell me on another.
I personelly feel that Demon brand Carbs are the best on the market. Even though the Speed Demon is an entry level carb, it has features like the higher priced models.
Bud
