Bob-
I've got to disagree with you slightly. I would not say what ERAs are "a lot" more expensive than SPFs. True if an ERA has an FE and the SPF has a windsor or 460 based motor, it will probably be more, but if you outfit both cars with the same engine they will be close (within 4-5K), which in the grand scheme of things is not that much more.
Replica is not a dirty word.
