Old 09-12-2003, 10:28 AM
REDSC400's Avatar
REDSC400 REDSC400 is offline
Cobra Make, Engine: ERA #375 427 S/C - 428FE - Toploader - 1968 AMX 390 Go Pack 4 Speed - My Daily Driver is a 2004 Crossfire
Send a message via AIM to REDSC400
Question ERA Modifications Possible to Existing Car?
Hi Bob:
On an existing ERA 427SC model, is it possible to add a glovebox and the dual pusher fans (in front of the radiator).
Just wondering. The current car has the dashboard that does not have the glovebox nor does it have the dual pusher fans in front of the radiator. The car currently has the electic fan that pulls air thru the radiator and it is mounted in the rear (engine side) of the radiator.
Typically, when the pusher pair of fans are set up, do they turn on at the same time (automatically) as the puller fan or do they come on when the water temp reaches a higher level (ie: via their own temperature sensor)?? Also, could the dual fans been set up via flip switch activated from the cockpit in a manual manner?
Are these modifications (installation of glovebox and fans) that I could undertake on my own? Or is the dash with the glovebox really best done as a swap out?
Thanks in Advance....
Art in CT
