Old 09-13-2003, 10:15 AM
KobraKarl's Avatar
KobraKarl KobraKarl is offline
Mike ,
It could be a couple of things, but if its"just out of the box" you probably need to adjust your idle mixture screws.
back your linkage idle screw off until the primary throttle blade is just opening
Turn the idle fuel mixture screws (on each side of your primary float bowl) all the way in GENTLY ! then back them out one complete turn, then back them out 1/4 turn at a time untill your engine does not pick up any more rpm. or if you have a vaccuum gauge until you have maximum vac.
then set your linkage idle
this should get you close, also check your timing ,
KK
Foolish consistancy is the hobgoblin of tiny minds
