Old 09-14-2003, 06:51 PM
Jim Maxwell Jim Maxwell is offline
Original Shelby Owner
Cobra Make, Engine: CSX 2401 street 289 Cobra and CSX 3288 Street "427" Cobra
Jimmy, There were three different sets of ratios used on the Cobras. The majority had the "L" set. The "M" set you have is rarer and advantageous for racing. Also known as the Sebring set, the ratios are close and are 2.36:1, 1.62:1, 1.20:1, and 1:1. The percentage drop in engine revs between third and fourth with the "M" is only 17%, vs. 29% with the "L" set. These two gear sets used Ford input shafts with 11/16 by 10 spline.
The third gear set was a "K" set, sourced from GM!
The M and K set gears are very, very rare and very expensive.
Tex Racing Enterprises in Ether, NC may be able to help you. They bought a lot of Holman and Moody's stock many years ago, and may have something lying around that could help you.
My experience with T-10's is that I would rather have a Toploader. In fact, I removed my T-10 from 2401 because it was always jumping out of 2nd and 3rd on deceleration. A rebuild lasted for omly a few months before I had the same problem. Cal Metal may have some words of wisdom for you. I know he is an expert on this topic.
