Old 09-15-2003, 02:46 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
Originally posted by CJ428CJ
I always thought light cars with high power to weight ratios were ideal for double pumpers. If you have a low power to weight ratio go with a single pumper with vacuum secondaries.
Mostly true.
You can sucessfully run a vac secondary Holley on a light car with good gearing, just put a really light spring in the secondary diaphram and sometimes, open up the orafice that has the check ball (in the diaphram housing) a little bit. You can get those secondaries to open almost immediately,
