Old 09-16-2003, 12:57 PM
CJ428CJ's Avatar
CJ428CJ CJ428CJ is offline
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
You definitely want to dial in your bellhousing using this procedure:
http://www.ac427.com/html/crc_print_28.shtml
However, with that said, your problem may be something else. Are you using the block plate between the bellhousing and the engine block. If that plate is not being used you could have an alignment problem. Sounds like it might also be a starter problem.
