Old 09-17-2003, 03:13 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
The tremec allready has a switch in it, see the connector on the side? That should be used to actuate an interrupt relay that will prevent the ign key switch from sending +12 to the starter solenoid, unless the tranny is in neutral.
