Weber Clearance-Calling Murt Farcus
Murt:
Have you ever shortened velocity tubes for 48IDAs to go along with a shorter set of stacks?
After listening (but not heeding) PEPI's advice to either:
a) drill a hole throught the motor mount and put a bolt through it or
b) put a spacer under the trans mount.
I ordered up a set of shorter stacks from Inglese. I have an extra set of velocity tubes which now need to be "cut down". Again Pepi (between bites of some Italian Blood Sausage) has prescribed the following: "Just get out your pipe cutter, measure and cut it off."
...and do the shorter stacks and velocity tubes impact other carb settings?
Morty
