Ahh yes,that was my first car and second also, I liked it that much. Since it was over 35 years ago, I can't say what you should look for. The typical things are broken exhaust bolts and studs, the engine is pretty rugged and trouble free if given just a little care. One thing to check or probably do is pull the valve covers and replace the gaskets and while it's open make sure the
oil drain back holes aren't starting to get built up with sludge, I've seen many an older FE that would fill up the valve cover after a few minutes and then start smoking terribly because it was over the top of the guides and being drawn in.One odd thing that happened to me and probably other cast iron cruiso owners, one day in traffic I stopped for a light and it never moved again. Turned out one of the
oil transfer tubes in the trans had come out and lost important pressure, nothing major except the tow bill. Pushed it back in after swedging the end of it and worked fine until it went down the road.
