Old 09-22-2003, 12:11 PM
rhino rhino is offline
Cobra Make, Engine: Contemporary, CCX 3748
Neasto, I had the same problem. I solved it by rebuilding the shifter. There are shim plates between the slector leavers. The shims wear and slip past the slector pin blocking if from sliding into the slector slot. Also be sure there is enough clearance around the shifter handle where it comes through the floor.
Rhino
