Old 09-22-2003, 08:37 PM
mstngjoe's Avatar
mstngjoe mstngjoe is offline
If you do enough research you will find both good AND bad about most of the crate builders mentioned. Also remember that performance engines rarely include any type of warranty/guarantee. Some may offer it for an additional fee.
IMHO, Squeeeq is correct. Better to have a problem across town than across the country.
I had a local machine shop do the work on my block. My family has been doing business with them for about 25+ years with never a problem. I did my own assembly after verifying all specs and doing the clearancing for the stroker crank.
I bought my kit from a local dealer and my heads came from JD's Performance in Florida.
When I build my next engine I'll do it the same way. But I will give a look at www.adperformance.com for parts next time. From what I can see and read, they are a top notch source with excellent pricing and outstanding customer service. Talk to Brian if you decide to check them out.
It's a significant investment. Just do the best research you can. Listen to the bad as well as the good.
Good luck.
'89 LX 408...SCAT, Probe, AFR 205, Vic Jr, Pro-Systems, Rawls sft cam, UPR K & arms w/coil overs.....more to come!
