fuel pumps & fuel pressure
Hello Sal,
If you choose a Holley carb go with the blue pump makes up to 14 PSI. I believe it comes with a Holley fuel regulator and costs about $100 that you may want to mount on your firewall or somewhere in your engine compartment. If you are going to use Holley or Demon carbs they require 6 1/2 - 7 PSI. If you decide to use the Edelbrock set your regulator at no more than 5 to 5 1/2 PSI . Most of the Holley red or blue fuel pumps are best suited for street applications. If you intend to race you may want to choose a different fuel pump.
Clois
"Let's roll"
"Be part of Something Good
