Thread: cooling fan
Old 09-23-2003, 05:17 PM
vettestr's Avatar
vettestr vettestr is offline
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
Hello,
As shown by temp comming down and being controlable when ram air or at speed your overall system is funtioning correctly. The problem starts when you lose ram air and even with no real load on engine. You need more air flow from fans! The shroud may/should help but create more air flow and problem will be solved.
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
