Old 09-23-2003, 08:39 PM
jamvan jamvan is offline
Cobra Make, Engine: Shelby Series 1 CSX5098 (w/ supercharger) & Diasio D962R Turbo race car
Bob:
Double checked the drive belt, while it was a little loose and did require a little tightening up, it still did not solve the problem. I then did check the connections as you recommended with a VOM.
While I can't determine that the VOM readings (at both the points you recommended) is the same as the amp gauge since the gauge is jumping around so much. I am getting steady readings on the VOM. Therefore, I guess what you will now tell me is that it is the gauge.
Anything else I should try before changing the amp gauge.
Thanks...jim v.
