Thread: What's Normal?
Old 09-25-2003, 05:14 AM
NeedAntiVenom NeedAntiVenom is offline
Cobra Make, Engine: ERA 289 FIA #2086, 302/320 HP, Dart heads, hydraulic
Greg,
Oil temp at 180-190 degrees, 2500 RPM, around 65 PSI. Idle can vary a lot but somewhere in to 25-30 range. Normal rod and crank clearances are at 0.0025"
With cold oil you may see 80+ pressures on startup.
If you can't get your oil temp up - you might consider a bypass/thermostat for the oil cooler.
Jim
