Thread: Got my Crossram
Old 09-28-2003, 04:48 AM
Default Intake question???
Geary L Sarno Geary I saw one of these intakes at Carlisle on Fordweekens 3 years ago. I saw going to buy it but, someone said that the disturbutor is special and did not come with it. There is an extension on it to clear the intake. I may be wrong but I would check into it. Paxton has the kit for special order to do the dual kit. You may want to go with the gear blowers over the ball blowers if you are looking for more or better boost. The ball blowers have small turbines and make about 6-8 psi. With the 1 V belt it will slip under boost. The plus side is you donot need a bypass valve for this kit. It will fir under the hook if you bubble it like Shelby and still look nice. Make sure you have an 1/2" fuel line and electric pump going to the carbs. Watch timing under boost. Keep it soft and a little rich. Good luck with it. Rick Lake
