Old 09-28-2003, 01:35 PM
Bart Carter Bart Carter is offline
Cobra Make, Engine: Levy Racing built FFR w/351W
Default Re: Which heads????!!!!!!
Originally posted by ridelikehell I'm at the point where I need to decide which heads to go with. My options are:
1. Leave the stock 302 heads the way they are.
2. Keep the stock heads, but port them.
3. Buy aftermarket heads.
In general if you modify the stock heads and compare them to off the shelf aluminum heads, you will find:
1. A well chosen AL head will make a lot more HP. Especially if you match a cam.
2. The price difference is not all that much.
3. The AL heads will make your car 50 lbs. lighter. That is 50 lbs. less to overcome for acceleration, braking and cornering.
Pay the extra few hundred for the AL heads.
