Old 09-30-2003, 11:46 AM
Chaplin's Avatar
Chaplin Chaplin is offline
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Chris-
Thanks for the explanation, that helps a lot. Now I can "see" what you're talking about. Mine is only rubbing on the top of the driver's side pipe- other side has a lot of clearance. I also have the Canton pan, and a good floor jack, so hopefully it shouldn't be too difficult. Looks like I have a weekend project.
I assume you loosenedd the passenger side mount as well? Also, did you need to loosen the trans mount or was there enough movement once you loosened the front mounts?
Thanks again,
Mike
Replica is not a dirty word.
