Twas not I... nor did I die. I do not lie, nor do I eat green pie. All is quiet on the eastern front, but do I want my cobra BACK FROM THE SHOP IN TIME TO TAKE HONEY TO THE WASHINGTON STATE OKTOBERFEST???? yes
It's a problem with the
oil ring fitting on the clutch hydraulic slave cylinder (second time it's blown out, but we are adding a pedal travel stop and a new "hard" type slave this time, no o rings. Also my Richmond gear 6 speed was almost dry when it was checked at the shop. Apparently it has a slow leak so we are disassembling it and giving it the once over, and it's probably OK, just had some small leak in the case joint or the silicone plug. It's a "split case design" with silicone in the seam) hopefully it will back in action in time. Hope you are enjoying your snake as much as I am.. they are great cars, and unlike any other
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
