Old 10-01-2003, 10:20 AM
leslie.files leslie.files is offline
Cobra Make, Engine: Excaliber body, Modified Custom frame
If you have jetted and adjusted your carb then you probubly also adjusted your float levels, so this may not help, but, If they are a little high than fuel will seap and load up your cyls. When I was racing I found that the see through glasses in the bowls help alot and the level should be at the bottom of the sight glass. I was loading up at low RPM's but needed everything I could get @ 7500RPM. I also found one of my floats was holding a small quatity of fuel changing how the float adjusted. Hope this helps.
Tohmer
"Ask not what your country can do for you, but what you can do for your country" JFK
