Old 10-01-2003, 05:42 PM
Hal Copple Hal Copple is offline
Cobra Make, Engine: Superformance, 396 CI
good suggestions above. I use the 2 quart model. I did have the first solenoid on the electric valve go bad, i had inadvertently wired it to always on, not just on with the switch i put in, so it burned out in a month or so.
Are you sure you have the valve pointed the right way? the little tiny arrow points away from the A'sump. I bled mine when new down to about 7 psi, then it will fill to read about the same as my engine's oil pressure mechanical gage does. When i turn on the switch to pre-oil, i can hear a gurgling sound as it pushes oil into my motor, at my filter block adaptor. My pressure rises to about 20 psi, and slowly bleeds down.
Are you using a check valve, it may be in wrong way, i don't use one. You might slighly loosen a fitting, and see if it leaks oil when discharging at pre-oil, and try running a power line directly from the battery to the switch on the Asump. , in case you are not accurately powered, i wasn't for several months at first.
My guess is that you are not actually powering the switch, so it fills but won't discharge.
please report back.
Hal Copple
Stroked SPF
"Daily Driver"
IV Corps 71-72, Gulf War
