Old 10-01-2003, 07:06 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Nothing heavy duty needed. The factory mounts were aluminum barstock drilled for the 1/2-13 through rods. McMaster-Carr (mcmaster.com) carries.
I put bumperettes on mine an need extra clearance in front, cut sections in back. Did some bracketry to fit OEM AC pieces from England (cobraspares.com). And Home Depot plumbing dept for grommets. Have shots if interested.
Can go under car for some measurements. How fancy or plain are you planning?
