The BHJ FO-IBFE-7 FE Dampner uses stock position everything and no additional parts are required. It works well with a March 1910 Pulley set which has the correct Ford size Crank, water pump and alternator pulleys, A stock seal sleeve is also used.....
http://www.bhjinc.com
George
