typically it should be about 1/2-3/4 turn beyond zero lash. If you have stud mounted rockers, lock 'em down and you're set.
If you have pedestal mount, they should torque up within 1/2-1 turns beyond zero lash. If they don't torque up, you need longer pushrods. If they torque up too soon, you'll need to shim under the pedestal.
EDIT - I should have mentioned that the adjusting should be done while that particular lifter is on the base circle of the cam (i.e. when the cylinder is at TDC on compression)
Wade Chamberlain
