Old 10-02-2003, 07:56 PM
decooney's Avatar
decooney decooney is offline
Did you change the jets in the Demon carb? If so, what were they before and what are they now; primary and secondary.
What # discharge nozzles are on the carb?
What are your idle mixture screws set at now? You can turn/count the turns in and start from scratch again too...
Are you sure you don't have some sort of a vacuum leak somewhere?
Did you run the car with this same engine and carb during a previous year of colder months, and did it do this then?
...just a guess, but I'm wondering if the popping you are hearing is a lean condition til the motor warms up just a tad...
Check your fuel pressure too. What is it?
Duane
