The close ratio has a higher low gear so depending on the torque of your motor, steel or aluminum flywheel, rear gear, etc. you may like it or you may not. The close ratio works a little better for for downshifting on short tracks the wide ratio will hit the rear tires if your not careful. It really depends on what you are going to do with the car.
Brent
