Old 10-03-2003, 09:18 PM
Cobra75's Avatar
Cobra75 Cobra75 is offline
Cobra Make, Engine: CSX 4100-Shelby 75th Anniversary Edition
Send a message via AIM to Cobra75
Lightbulb
Art,
You might try one more experiment to test the accuracy of your oil temp. Since the bourdon tube from the temperature pickup is open to the airflow beneath your car, it may be getting cooled by the airflow. Try wrapping the first few inches with some insulation...even a rubber hose taped over the tube would work.
One my friends with a small-block had this same issue, and after this "modification", the oil temp read 10-20° higher! Having said that, you will probably find that you will need to block the oil cooler intake in cooler weather. I like the foam idea...sure beats the cardboard I used last year.
Scott Harrison
CSX4100
Growing old is mandatory...growing up is optional.
