Originally posted by blykins
Bob,
The sending unit itself does not have teflon tape on the threads...but I had to use a nipple and a 45 to get the sending unit out of the way....on those I put teflon tape. Is that a bad thing?
If it interferes with the sender's electrical connection to the block!
If you have jumper cables, use one between the sender and battery or chassis ground. If the gage works then, the problem is the tape.
