Clois,
I have a "totally stock " fuel log , mechanical pump, with stock 1965 2x4 setup..........and I have run the hell out of it without ever starving.......
You may have had a bad pump, But I dont believe you can improve fuel flow by replacing the log.....the stock log will allow at least as much fuel as your new set up .....you will get to separately meter your fuel .......but I dont see the advantage of that..........
my two bits ,KK
Foolish consistancy is the hobgoblin of tiny minds
