Thread: blower
Old 10-07-2003, 08:00 AM
KraZMechanic KraZMechanic is offline
Send a message via AIM to KraZMechanic
Default Re: 351?
Originally posted by RICK LAKE
Mike get a lightening wreaked and put the motor in your cobra. Build a 392 or 408 9.0 compression aluminium heads 10 lbs of boost. 1/2" fuel system and 2 pumps. Watch the timing, don't go too lean and you have 600 hp This aabout all a cobra will handle and still be driviable on the street and 92 gas. Your are better to build a torque motor with 600 ft lbs. It is easier and more fun to drive. Rick Lake
I agree, the trick to keeping the octane requirement low is the compression. I have one friend with an 02 gt mustang running 9 lbs of boost thru a saleen blower on a stock bottom end, he's having no problems. I have another friend running an 03 cobra (8.5:1) with about 30 lbs of boost, and he's still running it on pump gas. we've got 93 octane out here in MD, which is good enough for most of the gearheads around here, but if not, the shop I work at sells C16.
