Old 10-08-2003, 04:43 PM
REDSC400's Avatar
REDSC400 REDSC400 is offline
Cobra Make, Engine: ERA #375 427 S/C - 428FE - Toploader - 1968 AMX 390 Go Pack 4 Speed - My Daily Driver is a 2004 Crossfire
Send a message via AIM to REDSC400
Default Brake Line and Clutch Bleeding
Hi Bob:
I would like to flush out the old brake and Clutch slave fluid and replace this with new fluid.
First off, on my #375 which fluid do you reccomend? I was given a pint of Willwood fluid from the previous owner and it is nice fluid as I have used it before.
Second Q.... Which brake caliper should I start with first, second third fourth and fifth. (ie is the Clutch slave last or first or if neither where in the sequence? It appears that they both work from the same bifurcated reservoir? Yes?
I would like to use one of those vaccuum pump one man fluid extractor gizmos....
Does anyone have any suggestions as to which to buy? Some of these can do double duty as an oil sump extractor, trannie fluid and rear banjo fluid too.
Best
Art in CT
See My Website at http://www.lithicsnet.com
A car can massage organs which no masseur can reach. It is the one remedy for the disorders of the great sympathetic nervous system. Jean Cocteau 1889-1963, French Author, Filmmaker
