Old 10-09-2003, 06:34 AM
NeedAntiVenom NeedAntiVenom is offline
Cobra Make, Engine: ERA 289 FIA #2086, 302/320 HP, Dart heads, hydraulic
Art,
I can't help you with hookup info. I was concerned about excessively low oil temps with a cooler installed, and found it while looking for oil thermostats. My engine builder said I would not need a cooler for street, so I had the oil cooler installed but not connected. Should I have oil temp problems in the middle of summer I'll plumb the oil cooler and install the thermostat.
BTW, I would hope the cooler is either a proportional bypass or has some sort of bleed through so that the motor doesn't get a slug of cold oil when it opens.
Sorry I can't be of more help.
Jim
