Thanks Roscoe.
What did they do, look at the a/f chart and give you recommendations on the proper jetting?
Dane-
Did you have to bring the jets and new metering plate or did they supply the parts? Also, those numbers are real wheels correct? Very impressive. I read recently in one of the magazines that you can expect about an 18% loss in power from your crank to your real wheels, so you are putting out some healthy numbers at the flywheel.
Mike
Replica is not a dirty word.
