10-09-2003, 05:13 PM
ESP
Cobra Make, Engine: Contemporary with 482 KC/SO, TKO600,IRS Jag/AMP, 3.54 Salisbury PL,
either your bowl float is not closing the inlet valve ( too much fuel pressure from your electric pump and no regulator) or you have no plunger inside the accel.pump injector body and the engine is drawing gasoline from the pump injectors.
