Old 10-09-2003, 05:33 PM
wtcobra wtcobra is offline
Cobra Make, Engine: Contemporary-Aluminum 484 FE
Where did the water originate? I don't know about the 460 for sure but on the FE's you would get a oil leak if the ends of the intake were not properly sealed. I use the end seals and silicone sealer. I also fit the intake and measure the ends to determine how thick a seal to use, and cut the seal material accordingly. If it leaks, I redo it, no big deal.
wt
