Old 10-10-2003, 08:00 AM
Back in Black's Avatar
Back in Black Back in Black is offline
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Unhappy Yeppers
There's another thread around here where other Richmond 5 and 6 speed owners are singing the same tune... mostly the front retainer seal leaking... I can tell you that I did not run her hard either, since she only has about 3K on her now, and everything seemed to be balanced in there (clutch/lakewood bellhousing) so it's a factory defect. Thanks Richmond !
By the way, we are going to a much better McCleod clutch.. the Centerforce 2 dual friction gave up after 2k and then more than 450 hp applied it would slip...
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
