Old 10-11-2003, 04:46 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
No neutral safety switch. I may not have explaned the push start correctly.
I put my car in second gear and let out the clutch and turned the key on and the starter moved my car forward about 3 feet and it fired up. I immediately pushed in the clutch and pumped the accelorator a couple of times and then put the car in first gear and drove it into my garage and killed it. I tried to start it again and nothing but a spinning engine.
I have worked on a time line of changes I have made and when this all started happening I had just replaced my needle and seats with off road needle and seats. I never had a problem with my engine starting before.
"Let's roll"
"Be part of Something Good
