You mentioned you moved your MSD. Did you also move your ground to the MSD?
1. Try an alternate ground for your MSD
2. Do you have a ground strap in the front of the car?
3. Check to see if your 12v power wire to the MSD is getting voltage when you try to start the engine. (use a tester light or meter if you have them.)
James
