One more thing before you send the box, is the coil good?
With verified voltage to the positive terminal, did you tap the negative side to ground?
Every time you hit ground, the coil should spark.
Hey, you can never tell about electrical in a car.
However, if the coil is good, you can not beat the $65.
Sorry to hear of your problem.
Trularin
