Old 10-14-2003, 08:34 AM
REDSC400's Avatar
REDSC400 REDSC400 is offline
Cobra Make, Engine: ERA #375 427 S/C - 428FE - Toploader - 1968 AMX 390 Go Pack 4 Speed - My Daily Driver is a 2004 Crossfire
Send a message via AIM to REDSC400
Question Differential Gear Changes
Hi Bob:
One of the things I am considering is the change of the rear differnetial gears in my ERA. The rear end is from a Jag XKE Series 2. Vintage is some time between 1964 and 1973 but that is all that is known.
Here is the first question:
Is the changing of the differential gears and posi unit a bench job or is it a job that can be done to the rear end in place? ie: is it a "quick change" or is it a detailed and delicate operation?
Second:
You list Michigan Driveline and SICP as possible sources for new gears. However, Michigan's and SICP phone numbers as listed in the Assembly Manual are defunct. Got new numbers on them?
Third:
Other than the gears, what else would need to be changed, ordered, etc. I assume the Toploader's speedo gear?
4th:
Do you guys have access to all the parts I would need? And can you do the gear change if it is not a quick change operation?
Much thanks,
Art in CT
See My Website at http://www.lithicsnet.com
A car can massage organs which no masseur can reach. It is the one remedy for the disorders of the great sympathetic nervous system. Jean Cocteau 1889-1963, French Author, Filmmaker
