The Ford Racing tech line, so I can get the torque specs on my motor...
I thought I would follow up/report that the split case WAS leaking... it came that way from Richmond. It has less than 3,000 mostly easy miles. At this point I would not recommend one, if this is what they call quality control.. we are inspecting it today, splitting the case and re-sealing with heavy equipment case sealant. We put dextron in it and it seeped out of the entire leading edge...
New McCleod clutch and heavy duty pressure plate, "hard" slave cylinder for the hydraulic TO bearing, and a new pedal stop install should solve matters. We are going to pull my pan to verify that there is no bearing damage, before replacing the intake gasket, etc...
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
