Old 10-14-2003, 06:31 PM
cwmcobra's Avatar
cwmcobra cwmcobra is offline
Smile Richmond 5-Speed
If mine leaks, I can blame myself. I had to replace the input shaft before assembling to the engine (don't ask.....), so I resealed the entire case. So, I'm hoping the RTV holds up well and that I hit all the right spots. I'm very familiar with the split case.
Good luck with your fix. Hope it solves the problems. I'll also be installing a pedal stop to protect from blowing out the o-ring in the hydraulic throwout bearing.
Chuck
