This has been a common problem with a lot of SPF's....I've had both of mine break, one twice! There appeared to be a problem with some of the pipes where they were welded. The problem was pretty prevalent in cars in the 700 series. The metal appeared to have been overheated and it crystalized where they were welded. SPF has reinforced the rear mounting brackets in their newer cars, but I can't tell you the car number when they began this practice.
Are you a SCOF member? If so, there are some pictures posted in one of our members albums of a re-inforcing modification he made to his pipe to alleviate this problem. I've made the same modification after one of my brackets broke the second time. So far, it appears to be a good fix.
Also, if you're running the original engine mounts made of rubber, you'll continue to have problems with these brackets. All of the rubber mounts are now being made in India, and ... bless their little hearts ... they have a completely different idea of what a 'Cobra' really is... These mounts are crap...period. Olthoff Racing has designed and sells a poly-urethane engine mount that really limits engine movement caused by torque. They really make a huge difference, and so far, this has helped to solve the broken side pipe mounts. You can reach Olthoff Racing at 800/297-6253. Tell 'em Flyin-Freddie sent ya...they know me well!
Hope this helps!
Flyin_Freddie
"An opinion on everything...an expert at nothin'!"
WARNING: The opinions expressed herein do not necessarily represent those of the management, editors, or owners. We welcome differing opinions, and recognize our responsibility to offer differing views. May cause drowsiness, restlessness, or irritability. Do not operate heavy machinery while using this product. Void in Alaska, Hawaii, and Puerto Rico, or where prohibited, licensed, or regulated by law. We reserve the right to limit quantities. Offer good while supplies last. No substitutions allowed. Please observe posted speed limits. Professional driver on closed course. Do not try this at home. Please wear your seatbelt at all times. Close cover before striking. Use at own risk. Please dispose of properly. Drink responsibly. Prolonged exposure to vapors has been shown to cause cancer in laboratory animals. Do not use this product of you are pregnant, or plan on becoming pregnant. Intentional misuse by deliberately concentrating and inhaling fumes can be dangerous. Always wear safety glasses. In case of eye contact, flush with water and seek immediate medical attention. For occasional use only as directed. Avoid prolonged skin contact. Discontinue use if rash develops. If symptoms persist for more than three days, seek professional medical attention. Hearing protection required beyond this point. Danger: Hot surfaces. Use as directed. Proceed at own risk. Caution: Filling may be hot. Please don't litter. Actual results may vary. It is a violation of Federal Law to use this product in a manner other than as intended. Do not use this product if you have an enlarged prostate, or have difficulty urinating.
