Why do you have to convert?
I don't recommend them unless there is no other viable option for your car. As soon as the O-rings leak, you have to pull the tranny (or motor) to replace the seals. You will need to replace the O-rings after some time, that's why they give you the first replacement set in the box with the TO. If there is any room at all to install a slave cyl and use a fork, DO IT. When that needs service, it is all external.
